AntoineSfx Posted November 17, 2018 Share Posted November 17, 2018 How do you handle this without any loss ? They are not equivalent in general, so I can't just convert from point to primitive or the converse. Also, how do you debug such problematic merge ? The exclamation point is just nagging me (in a good way...) Quote Link to comment Share on other sites More sharing options...
Atom Posted November 17, 2018 Share Posted November 17, 2018 You just have to balance the merge input lines so they each have the same attributes. I do this by adding missing attributes on one line using a wrangle or attribute create and or using attribute delete or promote on another to remove unneeded or missing attributes from other input lines. Most of the time I ignore this, however. I only take the time to match unbalanced attribute merges if I need the viewport to work correctly. If you have unbalanced @Cd one side will win and the other will lose often producing the wrong color in the viewport. Quote Link to comment Share on other sites More sharing options...
