recursively select all 'visible' node in subnetwork ?
SciMunk
I need to be able to select all visible node in a subnetwork (which himself have other subnetwork) to put into the "Forced Matte" of a rop node, I cannot find any information about that or if it even possible.
Thanks a lot for any help on that !
Edited by SciMunk
title typo
It can be done, you need scripting for that. Here is a python snippet that shows how to assign a string to the Mantra node Forced Matte field. I don't think recursion is actually needed. If the object in the subnet is not visible then all the children are effectively disabled as well.
subnet_node = hou.node("/obj/subnet1")
names = ""
for child in subnet_node.children():
    if child.isDisplayFlagSet()==1:
        names += "%s " % child.name()
mantra_node = hou.node("/out/mantra1")
mantra_node.parm("matte_objects").set(names)
ap_subnet_to_forced_matte.hiplc
Edited by Atom
Thanks for the script Atom,
I was hoping there would be a more procedural way to do it directly inside the parameter ? script require to be executed everytime change are made and when doingIPR (I'm using the redshift ROP), after a while it can start becoming annoying if we often disable/enable node for testing.
can your script be used in the parameter as a python script ? if yes, can I have a little exemple as I never managed to make a single python parameter working, alway getting some error.
thanks you!
For Redshift you would have to target the Redshift ROP instead of a Mantra node.
names = ""
mantra_node = hou.node("/out/Redshift_ROP1")
mantra_node.parm("RS_objects_forceMatte").set(names)
  • 2 years later...
names = ""
Hi !
@Atom maybe you know this one...  :)
Im trying to identify which nodes make the size of a file huge, is it possible to loop to all parent node and subnetwork child and look for stashed or locked nodes in python?
give back the absolute network path for example...
Cheers,
vincent*
Watched Matrix trailer yesterday and makes me want to play with the primitive sphere a bit... Refining my custom tool and design rules ;)
________________________________________________________________
Vincent Thomas   (VFX and Art since 1998)
Senior Env and Lighting  artist & Houdini generalist & Creative Concepts
 http://fr.linkedin.com/in/vincentthomas
