kiryha Posted November 28, 2018 Share Posted November 28, 2018 How to add a new path to environment variable? For example, trying to add a new path to the "PATH" (i need HOUDINI_PATH indeed): import os print os.environ['PATH'] os.environ['PATH'] = 'C:/TEMP;&' print os.environ['PATH'] >> C:\Program Files\Microsoft MPI\Bin\;C:\Program Files\Java\jdk-10.0.1\bin; ... >> C:/TEMP;& So, os.environ['PATH'] = 'C:/TEMP;&' overwrites existing "PATH" variable. This way os.environ['PATH'] += os.pathsep + 'C:/TEMP;' is working. I was thinking "&" should do the trick (append a string to the variable instead of replacing it), but it does not work. So I wonder if I misunderstood something with "&" and "+=" is the only solution. Quote Link to comment Share on other sites More sharing options...
hall Posted December 13, 2018 Share Posted December 13, 2018 os.environ["PATH"] += os.pathsep + os.path.join(path) Quote Link to comment Share on other sites More sharing options...
