I3d Smoke-control :)
Val
hey.
I still 'researching' -best way..
Idea is
to render 2 passes, one with i3D
and one with metabols-RGBA..
then in digital fusion use 'channel boolean'
or in nuke - 'shuffleCopy'
to get ALPHA from metabol-RGBA ...
(or transfer any channel.. to colorise smoke)
this way you can color or dissolve smoke based on particles AGE or LIFE
I attaching simple test, I was playing yesterday to see if works..
for me looks promising :D and I will keep working
to get nice details on i3D-smoke.
Val
I would imagine you could edit the default vex metacloud shader, to write an additional color channel, that could then be read back in to color the i3d's on final render. I havn't tried this but I believe something like this is possible.
~MP
~MP
27682[/snapback]
Hi HyFrmn.
thank you for reply!
I am new to houdini..
and discovering how to do staff..
I do not knew I can edit that shader.
I was thinking it is possible just transfer Cd to i3D,
I did search, and
and find this:
http://odforce.net/forum/index.php?showtopic=3998&hl=
no one reply, and I start thinking it is not possible, and I start
thinking another way to do this :)
I will try to do...
Thank you very match for pointing correct direction!
Val
I find tutorial!!!
http://www.odforce.net/tips/shader_wiritng_i3d_2.php
This is definetely possible, and not "too" difficult. People keep asking about it. I have an old file I keep digging out, so I'll try and clean it up at some point and post it.
27688[/snapback]
Hey.
yes.. I did tutorial from odforce, and I am very excited
and happy with 'control' over shader.
When I get good at doing this..
I am thinking about not telling others.. :D:D:D
like other users do (JK)
Val
Hey.
Val
27728[/snapback]
Its not that nobody wants to tell you . Just getting color information into and from an i3d file is simple (ive attached a file to show you how simple it is ). The hard part starts with getting your clouds to render with realistic scattering and shadows and thats not something someone can explain you with 10 lines of text and a simple hipfile and i think nearly nobody would do something like that with vops .
Sven
i3dExample.hip
thank you Sven :)
I start learning houdini few month ago...
I do not even know if it is possible or not,
just trying to find info-help-tutorials....
( hmm.. I think, I do not put you in my black list..
I will make final decision after checking your file ;)
thanks again!
Val
The color info from a Color POP is in the Cd attribute.
When you import your particle animation to SOPs using MergePOP you get this, and the rest, of attributes.
You only need to knoe how to read this attribute in a i3D Shader, you can use the mattrib function to retrieve info from the metaballs to you i3d texture.
Be careful about the corrd space you use, it depends of the effects you want to use.
Useful links in the houdini help:
hdox://houdini/content/vex/contexts/image3d.html
hdox://houdini/content/vex/vex_cat_i3d.html
Good luck
