Convert images using icp ?
I read you can use icp the command line tool to convert one format to the other.  Therefore I run the command icp <ConvertFrom> <ConvertTo> but I get an error; unable to create the <ConvertTo> format file ? In other words, if I want to convert from TIF to PIC, it's unable to convert the file to a PIC file format ? And what was or is Halo ?
9 hours ago, bunker said:
icp img.tif img.pic
icp img.tiff img.pic
both work for me, with 8/16bits images, alpha channel and even layers (although they get flattened)
what command are you running?
icp Acme.tif SuperAcme.pic
I'm running the command in the same folder as the Acme.tif file within a Houdini command line.
