Assign stitch point constraints in DOPS (animate-able)
sessionbeer
I'm trying to wrap my head around why this simple set up isn't working as desired.
Inside of an SOP solver, I look for the first and last points on a curve and assign them to groups.
I then try and assign these groups in the Stitch constraints on a multi-solver but they aren't taking effect. Can someone point me in the right direction?
I know this is simple in SOPS level but I'd like to expand upon this in DOPs and make the Stitch points animate-able.
Thank you
constraint_simple_01.hiplc
and how do you know it's NOT working ?
if it was NOT working.....then the 2 ends should simply fall down...but no....the string hangs on the tube, proving the stitch works. And yes, if I enable Breaking with low enough threshold......it will break. If you don't like the 'gap' between the ends, use Weld instead.
Edited by Noobini
