demoan666 Posted December 29, 2018 Share Posted December 29, 2018 (edited) hi i have a grid, with color on red channel (randomly varying value), on certain primitives. now i want to extrude each primitive based ot their respective @Cd.r values. any thoughts? i would appreciate any help! thanks Edited December 29, 2018 by demoan666 Quote Link to comment Share on other sites More sharing options...
Alexey Vanzhula Posted December 29, 2018 Share Posted December 29, 2018 paint_extrude_example.hipnc Quote Link to comment Share on other sites More sharing options...
anim Posted December 29, 2018 Share Posted December 29, 2018 or don't use loop just Poly Extrude in Individual Components mode, check Distance Scale in Local Attributes, put your prim attribute name in there, and play with Distance slider the distance will be multiplied by values in Distance Scale attribute per component 2 Quote Link to comment Share on other sites More sharing options...
demoan666 Posted December 30, 2018 Author Share Posted December 30, 2018 On 12/29/2018 at 2:46 PM, Alexey Vanzhula said: paint_extrude_example.hipncFetching info... Expand thank you Alexey so much for the tip! Quote Link to comment Share on other sites More sharing options...
demoan666 Posted December 30, 2018 Author Share Posted December 30, 2018 On 12/29/2018 at 4:01 PM, anim said: or don't use loop just Poly Extrude in Individual Components mode, check Distance Scale in Local Attributes, put your prim attribute name in there, and play with Distance slider the distance will be multiplied by values in Distance Scale attribute per component Expand <3 Quote Link to comment Share on other sites More sharing options...
Alexey Vanzhula Posted December 30, 2018 Share Posted December 30, 2018 On 12/30/2018 at 9:30 AM, demoan666 said: thank you Alexey so much for the tip! Expand As noted above, it is better to use the local extrude feature. I just wanted to show how to do it in loop. Local extruding (without loop) has better performance. Quote Link to comment Share on other sites More sharing options...
demoan666 Posted December 30, 2018 Author Share Posted December 30, 2018 (edited) On 12/30/2018 at 9:45 AM, Alexey Vanzhula said: As noted above, it is better to use the local extrude feature. I just wanted to show how to do it in loop. Local extruding (without loop) has better performance. Expand i agree, however, i am trying to understand the various loops, so thanks a lot Edited December 30, 2018 by demoan666 1 Quote Link to comment Share on other sites More sharing options...
