Mantra Rendering
the prob. is the "white  point" on the picture
27868[/snapback]
The white spots is an artifact, but what are the regularly placed dots??
Try the trick and increase near param in camera view tab to 1 or something, this usually kills most artifacts.
I'm not sure why there are no splatches on the body?
hey peliosis,
i think i found the prob. well, after having created a group and a shader for mapping a part of my object .the prob is that the normals "flip" when i move the camera! my test was
mapping with "two sided" and in 2 differents colors. finally if a move my camera sometimes
there is color 1 and another color 2 .... very strange :ph34r:
is there a solution for that?...
hello DaJuice, hello peliosis
DaJuice, i'm going to install 7x.xx driver under fedora 5 and i see...
peliosis, "I thought your pics were taken from the viewport..." Yes there are!
if i do a mantra rendering at this moment the result is sometime good sometime bad ..
thanks you a lot! :rolleyes:
This is probably a real stupid question but are there two sets of primitives in there? Try turning on prim numbers in the viewport and have a look.
It wouldn't be the first time I got duplicate sets of primitives while modelling...
