export VDB data to a 3D matrix into a txt file
Alexandre
I found some startup ideas here : https://www.sidefx.com/forum/topic/56423/?page=1#post-255419
I use a py node for data export, with vdb visualize tree because the py node from the link export data geometry spread sheet
now I need to find how to reshape the vdb_float attribute (in relation to ptnum) from geometry spreadsheet in order to get a 3D matrix (basically, a matrix of 0 and 1 for a binary object)
Edited by Alexandre
Can someone help me on that ?
I am diving in python world and found some help using houdini doc : http://www.sidefx.com/docs/houdini/hom/hou/VDB.html
I have basically written the function found at the link above, and I try to use this function on my vdb volume (filled inside) but it seems that the object has no attribute 'activeVoxelBoundingBox' :/
I'm 100% sure the problem comes from me, so if someone can put me on the right track I would be grateful
thanks
Edited by Alexandre
here is the example
connect the Python SOP directly to the geo whose first primitive is the VDB volume you care about
import numpy
node = hou.pwd()
geo = node.geometry()
vdb = geo.iterPrims()[0]
vdbRes = vdb.resolution()
vdbBounds = vdb.activeVoxelBoundingBox()
values = vdb.voxelRange(vdbBounds)
values = numpy.array(values)
values3d = values.reshape(vdbRes, order='F')
print values3d
