catchyid Posted January 3, 2019 Share Posted January 3, 2019 Hi, I am trying to understand the basic physics behind fluid simulation used in Pyro solver. All physics books say that density must be constant (otherwise the equations will be too hard to solve). However, when I do any smoke sim in Pyro, density field is not constant, i.e. one can compute max/min/average density for a Pyro smoke simulation. So my question: how come all books say that density must be constant and yet when I sim smoke in Houdini I have different densities? Thanks, Quote Link to comment Share on other sites More sharing options...
anim Posted January 3, 2019 Share Posted January 3, 2019 It refers to different density - density of the fluid like air or water is assumed to be more or less constant, however in sims divergence affects how much the fluid compresses or expands which can be linked to temperature or other fields to achieve more realistic results of "changing" density of the fluid - but density field in pyro doesn't represent density of the fluid. It is more like density of the solid matter suspended in the fluid, that is observed as smoke As regardless of whether you have nonzero density field or not, you can solve for fluid motion 1 Quote Link to comment Share on other sites More sharing options...
Noobini Posted January 3, 2019 Share Posted January 3, 2019 I think you should change (if possible) the thread title to Incompressible Fluids. Incomprehensible = WTF ? 1 1 Quote Link to comment Share on other sites More sharing options...
catchyid Posted January 3, 2019 Author Share Posted January 3, 2019 Thanks Tomas! So one way to see pyro density as just a property advected by velocity field, and dissipation parameter removes percentage of it on each frame? As per divergence, can I think of it as a way to adding/removing the density property above? As per vusta, sorry, simple typo Quote Link to comment Share on other sites More sharing options...
toadstorm Posted January 4, 2019 Share Posted January 4, 2019 Divergence isn't adding or subtracting density... it's a property that's automatically computed by the Gas Project Non Divergent microsolver inside the Pyro solver. It represents areas where the velocity field is collapsing or expanding, which is generally a no-no when you're trying to simulate incompressible fluids. The microsolver does some complicated wizardry to remove the divergence from the velocity field, which gets you that characteristic swirly motion you expect. That microsolver also has the option to provide a "goal" divergence field, which allows the user to define areas where they actually want the gas to expand or contract. If you create a scalar field named "divergence" and source it into your sim, positive areas will expand and negative areas will contract. 2 Quote Link to comment Share on other sites More sharing options...
