How To Get The Name Of Created Operator?
hoknamahn
I want to add a new operator in this way... Say opadd -n null
After that I have to change some properties of that operator. Is it necessarily to have an opname to change it's properties? If so how to get the name?
I don't wan to set the operator's name manually.
Other problem is the creation of network box by script. Seems that is impossible. Am I right?
I always use the supplied script uniquename.cmd to set up a variable that builds the object name I want to add, then add it.
By predefining the name, you can do subsequent operations to that node easily
See the script in $HH/scripts/uniquename.cmd.
# Add an operator using uniquename.cmd
opcf /obj
set opbasename = "model"
uniquename.cmd $opbasename "varname"
opadd geo $opbasename_$varname
opset -d off $opbasename_$varname
One limitation to keep in mind is that it's quite possible a node to rename itself using their event scripts like "On Created" or "On Input Changed" and currently there is no way to access a node by a unique identifier which remains constant throughout its existence.
Recently I had an issue where a certain node renames itself based on who it's wired into so this would fail:
set name = `execute("opadd -v mynodetype")`
opwire $name -0 someothernode
# oops, the node has renamed itself due to its own OnInputChanged script
#  and I no longer know what it's called. eek!
Arhhh... opscript is confused me :) I create a network box and then do opscript and don't see anything about network boxes. So I've decided that HScript can't work with network boxes. :ph34r: I understand that network boxes are not objects but... That behaviour looks strange. :rolleyes:
27929[/snapback]
You can't just decide that without changing reality! ;) Arctor is right, all the nb* hscript commands are designed to deal with Network Boxes. Are they not working for you?
27935[/snapback]
My eyes... my meagre eyes :( I checked opscript again and now I see
/obj -> opscript -r /obj
# Automatically generated script: Wednesday May 24, 18:34
\set noalias = 1
set saved_path = `execute("oppwf")`
opcf /
# Node obj
opcf obj
# Network Box netbox1
nbadd netbox1
nblocate -x 1.30588 -y 0.623529 netbox1
nbsize -w 2.5 -h 2.5 netbox1
nbset  -m off -p off netbox1
nbcolor -c 0.52 0.52 0.52 netbox1
opcf ..
Huh... I must relax frequently :lol: Sorry guys for stupid questions :lol:
