bonassus Posted January 10, 2019 Share Posted January 10, 2019 I'm setting up type properties for an hda i'm working on. I would like to set the value of the range fields relative to the value of a different parameter. For instance set a window width parameter based on the wall width parameter. however the range fields in the operator type properties window only allows me to type in integer values. It wont let me type relative reference to the other parameter. Is there a way to do this? thanks Quote Link to comment Share on other sites More sharing options...
bonassus Posted January 23, 2019 Author Share Posted January 23, 2019 Hmm, maybe my question was confusing. Is there a way to set a type property parameter, the max range field for example to the value another parameter or variable using an expression? It appears that you cannot enter expression into type property parameter fields. Quote Link to comment Share on other sites More sharing options...
vicvvsh Posted January 24, 2019 Share Posted January 24, 2019 11 hours ago, bonassus said: Hmm, maybe my question was confusing. Is there a way to set a type property parameter, the max range field for example to the value another parameter or variable using an expression? It appears that you cannot enter expression into type property parameter fields. I guess you can not. But you can bind parameters of your hda with expressions Quote Link to comment Share on other sites More sharing options...
bonassus Posted February 4, 2019 Author Share Posted February 4, 2019 (edited) On 1/24/2019 at 2:05 AM, vicvvsh said: I guess you can not. But you can bind parameters of your hda with expressions thanks for your reply. in this case you cannot enter an expression into the range filed. it only accepts numbers. i think the best non pyton script solution can be found here: https://www.sidefx.com/forum/topic/11209/?page=1#post-53490 Edited February 4, 2019 by bonassus update Quote Link to comment Share on other sites More sharing options...
vicvvsh Posted February 5, 2019 Share Posted February 5, 2019 7 hours ago, bonassus said: thanks for your reply. in this case you cannot enter an expression into the range filed. it only accepts numbers. i think the best non pyton script solution can be found here: https://www.sidefx.com/forum/topic/11209/?page=1#post-53490 This is what i meant test_parms.hdanc I've made invisible an auxiliary parameter with expression 1 Quote Link to comment Share on other sites More sharing options...
bonassus Posted February 5, 2019 Author Share Posted February 5, 2019 (edited) 16 hours ago, vicvvsh said: This is what i meant test_parms.hdanc I've made invisible an auxiliary parameter with expression Ok I see. Thanks for the file it helped me see another way to control the parameter . In practice however i think this is equivalent to just clamping the value at sop level. As the sliders range isn't updated and can exceed the clamped value. I wish I could enter the expression into the range filed itself. thanks again. Edited February 5, 2019 by bonassus update Quote Link to comment Share on other sites More sharing options...
burakumincgi Posted November 6, 2019 Share Posted November 6, 2019 On 2/5/2019 at 5:02 AM, vicvvsh said: This is what i meant test_parms.hdanc I've made invisible an auxiliary parameter with expression great trick, very neat.. thanks for sharing Quote Link to comment Share on other sites More sharing options...
