nested if statements
MadMax50
hello,
I am trying to get a nested if statement to work properly in sops.
First I have my constraints being deleted by the Y value
then if the Y value is less than a certain value , I want to set @strength=-1 based on a random condition.
Then i want to delete all the constraints that are not @strength=-1
The result should just be  only the constraints that are @strength=-1  if it is below a certain @P.y value.
I am not sure what I am doing wrong here...
float myRand= rand(@primnum*234.234);
f@strength=100;
if(@P.y<chf("Thresh_Y")){
    if(myRand>chf("Thresh")){
        f@strength=-1;
            if(f@strength>0){
                removeprim(0,@primnum,0);
I will also attach my scene file for anyone that wants to take a look
Thank you.
nested_if_statements.hipnc
If I understood you correctly this is what you want, I put color instead of deleting so you can see what is happening. Add the removeprim function where @Cd is or put a blast at the end "@strength==-1" and check delete non selected.
f@strength=100;
    f@strength=-1;
    @Cd = {1,0,0};
    } else if (myRand>chf("Thresh")) {
        f@strength=-1;
        @Cd = {0,1,0};
@SepuThank you. I am trying to keep f@strength=-1 and delete everything else when it gets below a certain Y value.
Basically i am trying to achieve an rbd sim that breaks below a certain Y value but some pieces stay together.
I'll attach my scene with the simple rbd sim to show you what I mean.
I implemented your method into it but I am not sure how I will achieve this without another if statement in there.
Thank you.
nested_rbd.hipnc
this: float myRand= rand(@primnum*234.234);
is generating your random number based on @primnum, but since you are deleting constraints it will change each time so it will not be stable
create prim attrib on constraints before the sim, like: i@primid = @primnum;
then in your code use: float myRand= rand(i@primid*234.234);
you are updating positions of your constraints, I get that it's cause you want to detect the P.y, but you can't leave them like that
the constraint have to stay at rest, so just use it to create your attributes for deleting, then transfer those to original constraints and delete
depending on what you are doing you may be able to use clustering instead of having to alter stuff in DOPs, but I guess this is just a proof of concept for more complex behaviors
nested_rbd2_fix.hipnc
