Resample issue
reeson
it's because of your points order....turn on point numbers and you'll see.
As an example, say on the left side you have a line with pts 0-1, with 1 being the 'innermost'. Then on the right you have a matching line with points say 31-30...with 31 being 'innermost'.....when you create a new long line, it joins 1 to 30...which is OUTTERMOST, then it goes back in to point 31......it's out of whack.
In my file, you can use a simpler test case on the left, with just one line so you can easily observe the numbers, so imagine adding points 0-1-2-3 to create a long line, you can clearly see using add won't work, join will.
Haven't tested exhaustively....but the issue is the points order....get that right, resample will work.
vu_resample_issue1.hiplc
Edited by Noobini
