Vex create group
davidyannick
I wrote these lines to create a group frm my selection
Quote
int pointNum=chi("Ppointnum");
setpointattrib(geoself(),"Cd",pointNum,{0,1,0},"set");
int neighs[]=neighbours(0,pointNum);
for(int i=0;i<len(neighs);i++){
    setpointattrib(geoself(),"Cd",neighs,{1,0,0},"set");
    setpointgroup(0,"truc",neighs,1,"set");
 BBut the selection is ok but no group is created ??  I add a group sop and  the group "truc" is not listed ?
Can you help me please ? Thx
untitled.hipnc
Edited by davidyannick
your pasted code snipped is broken (missing  [] when calling member from neighs array ), but the code in the screenshot is ok, and in the viewport it looks like it works
so I assume your problem is that your Group SOP is set to Primitives instead of Points and that's why you don't see the group in the menu
same in the viewport, you probably have Prim selection instead of point selection
also you can MMB on the node to see if your group is created and how many points it has
Edited by anim
