Open UV View (Uv Editor ) in Python
Nour Almasri
import hou
desktop = hou.ui.curDesktop()
pane = desktop.createFloatingPane(hou.paneTabType.SceneViewer)
# Get the display settings
settings = pane.curViewport().settings()
I did this code which open a new window for the scene viewer , but missing the last step to switch it to Uv View  .
I've been looking for it and what I was able to find was just: hou.geometryViewportType.UV
This is used to test if the current viewport is for example a UV viewport. For example:
import hou
cur = hou.ui.paneTabOfType(hou.paneTabType.SceneViewer,0)
viewport = cur.curViewport()
if viewport.type() == hou.geometryViewportType.UV:
    print "is UV viewport"
else:
    print "is not UV viewport"
Also there is GeometryViewportSettings and viewportType but I have not been able to make them work correctly
http://www.sidefx.com/docs/houdini/hom/hou/GeometryViewportSettings.html
  • 5 weeks later...
import hou
# Assuming your newly created pane index is 1
cur = hou.ui.paneTabOfType(hou.paneTabType.SceneViewer, 1)
viewport.changeType(hou.geometryViewportType.UV)
Hope this helps :)
  • 1 month later...
