Loop with DOP and cache issues
kiryha
Hi guys,
I have a setup to Disintegrate Geometry (there two main parts: boolean geometry and emit particles). And I have a lot of geometry pieces to destroy, so I place this setup in a For Each Loop. The geometry works fine, but DOP simulation caches gives wired results (some sort of combined sims for each piece).
If I turn ON Single Pass in Lopp and play, everything is working. But I have to play so many times as many pieces I have which is not what I was aiming to get. Any thoughts?
How to use scene:
- Set display flag to ACTIVATE node, set Single Pass of "foreach_end1" to ON,
- set pass number = 0, play,
- set pass number = 1, play,
- check "SEE_RESULT" node, Geo and particles should work
Now switch to ACTIVATE again,  set Single Pass OFF, play, check result. The geometry is working, particles - NO...
vanish_006.hiplc
