PortalPyro98 Posted February 6, 2019 Share Posted February 6, 2019 (edited) I'm having problems with performing the initial Voronoi fracture with the attached piece of geometry. I'm guessing the problem has to do with either the object being made up of tri's or not having a base face. Any ideas ? Edited February 6, 2019 by PortalPyro98 Quote Link to comment Share on other sites More sharing options...
Sepu Posted February 6, 2019 Share Posted February 6, 2019 import to Houdini Alembic ROP or Alembic archive > unpack > Convert Then scatter points and use the fracture tool. Quote Link to comment Share on other sites More sharing options...
nuki Posted February 6, 2019 Share Posted February 6, 2019 (edited) In addition to that you also have to fuse and close the bottom with a polyfill. Else voronoifracture would produce atrifacts when I testd it in 17. Edited February 6, 2019 by nuki 1 Quote Link to comment Share on other sites More sharing options...
PortalPyro98 Posted February 6, 2019 Author Share Posted February 6, 2019 On 2/6/2019 at 4:53 PM, nuki said: In addition to that you also have to fuse and close the bottom with a polyfill. Else voronoifracture would produce atrifacts when I testd it in 17. Expand Perfect thanks Quote Link to comment Share on other sites More sharing options...
