reeson Posted February 10, 2019 Share Posted February 10, 2019 Hey guys. How could I delete all outside or random pieces without manually selecting them after a assemble node? Cheers! Quote Link to comment Share on other sites More sharing options...
Midasssilver Posted February 11, 2019 Share Posted February 11, 2019 (edited) You can promote the group from outside on the assemble node, and then delete after the assemble. Or, since the assemble turns each object into a single primitive (if you have pack geo enabled), you can drop down a group by range (or probably delete by range for that matter), then delete that group. If you need a random sort for those primitives to make the group random, just drop down a sort, and sort your primitive numbers, then the delete by range should do what u want. Edited February 12, 2019 by Midasssilver 1 Quote Link to comment Share on other sites More sharing options...
reeson Posted February 11, 2019 Author Share Posted February 11, 2019 Thanks! Quote Link to comment Share on other sites More sharing options...
