how to export individual rocks from a fracture
anicg
Assemble and check pack geometry. Now you have an individual object for each piece. Select the shard you want and use a delete node set to delete non-selected - you have now isolated your shard. Then make sure obj exporting is enabled in your preferences, and you can write out an obj with a rop geometry node with .obj as the extension.
