minzy Posted March 16, 2019 Share Posted March 16, 2019 Hi, I’m Houdini beginner I made ‘roll a dice’ work So I used RBD node, It was made that dice and ground are clashed Now I got problem After rendering I checking my work, I found dice’s glass material have keep changing I tried to get the value to 0 when the dice fell and stopped because of the bounce and friction values of the RBD node It looks better but still PROBLEM Quote Link to comment Share on other sites More sharing options...
tmdag Posted March 17, 2019 Share Posted March 17, 2019 (edited) Would be easier to debug with an example scene. but few questions: On 3/16/2019 at 3:57 AM, minzy said: glass material have keep changing - keep changing how ? ( i only guess you meant that jittering at the end of animation?) On 3/16/2019 at 3:57 AM, minzy said: I tried to get the value to 0 - get value of 0 of what? what value ? Edited March 17, 2019 by tmdag Quote Link to comment Share on other sites More sharing options...
minzy Posted March 24, 2019 Author Share Posted March 24, 2019 yes jittering Quote Link to comment Share on other sites More sharing options...
CinnamonMetal Posted March 24, 2019 Share Posted March 24, 2019 Increase your sampling within Mantra with regards to the jittering ? Quote Link to comment Share on other sites More sharing options...
davpe Posted March 25, 2019 Share Posted March 25, 2019 hard to say without inspecting the scene but i'm pretty sure this artifact is rather the geometry/animation problem than material/rendering thing. my guess would be either somehow jittery normals, doubled prims/edges or something along those lines. Quote Link to comment Share on other sites More sharing options...
Midasssilver Posted March 27, 2019 Share Posted March 27, 2019 My guess is that the jitter is present in the animation. There is already some weird velocities present on that 3rd bounce. The jitter at rest is probably a product of whatever is causing that. Perhaps you should enable sleeping on the RBD? Quote Link to comment Share on other sites More sharing options...
