Alternatives to using promote to detail
shadowst17
Hi guys, I was wondering if anyone had any suggestions on faster ways to get one attribute value to change a group of other attributes with the same name attribute. The usual method suggested is to use a for each node with the promote to detail set to max or min and then promote back to point. This is incredibly slow and the bottle neck for my setup. Anyone got suggestions on alternatives that are faster with the same outcome?
Edited by shadowst17
  On 3/19/2019 at 8:26 AM, bonsak said:
If you could set an attribute up stream to identify what parts of your geo you want to operate on, you might not need to use a for each.
-b
 I did think about that, I might try and have an array on each point of every other point that is in this piece.
  On 3/19/2019 at 8:57 AM, ThomasPara said:
do you have an example file?
Here you go, quickly cobbled it together.
example.hipFetching info...
Just use a point wrangle after "attribcreate1" with this:
//list all points in the group
int hit[] = expandpointgroup(0,"group1");
@Cd = {0,0,0};
//run over points that ar not in the group so @hit = 0
if(@hit == 0){
    //do something for each element of the array hit[]
    foreach(int i; hit){
        //take ID of the current element array
        int grp_id = point(0,"ID",i);
        //if the ID of the point is the same ID of this element of the array then also this point is @hit = 1;
        if(grp_id == @ID){
            @Cd = {1,0,0};
            i@hit = 1;
Edited by Andrea
  • Thanks 1
//set the wrangle to run over group1
int count = findattribvalcount(0,"point","id",i@id); //find how many points that have the same id
for(int i = 0;i<count;i++){ //run over the points and set the color or any attribute of your likeing
    int found = findattribval(0,"point","id",i@id,i);
    vector color = set(1,0,0);
    setpointattrib(0,"Cd",found,color,"set");
example_fix.hipFetching info...
  • Thanks 1
@Cd = {0,0,0};
if(@hit == 0){
        if(grp_id == @ID){
            @Cd = {1,0,0};
            i@hit = 1;
Thanks guys these have been really helpful!
Heres a version thats faster than the for-each, its some more nodes to make that happen. The wrangles "minimize_search", "find_unique", "set_search", and "set_color" has a combined time of around 1 sec, while the foreach is around 13 sec.
This runs over 5 mill points
example_fix_02.hipFetching info...
Edited by ThomasPara
  • Thanks 1
If you set the scatter to 30000 points for example, the wrangle is twice as fast as the for each node version.
-b
EDIT: This was when testing the example-fix.hip
Edited by bonsak
Excellent! This is even better, thank you.
  • 1 year later...
