Rendering Redshift PDG instances with HQueue
I have 2 a computer "farm" setup to render out PDG wedge iterations.
Rendering it with Mantra works fine with local scheduler as well as with HQueue.
Redshift works just fine with the local scheduler but when rendering with HQueue it renders out just one frame of my iterations without any error messages.
The frames are numbered by @wedgeindex which apparently worked for 3/4 of the cases listed.
Any ideas?
Thanks
Hendrik
Edited by hendrikc
On 28/03/2019 at 8:37 AM, hendrikc said:
Any ideas?
Thanks
Hendrik
No experience to help you, I'm afraid, but if you haven't seen Entagma's PDG tutorial on Redshift rendering, you might wanna check out towards the end - seem to remember they demonstrated and fixed a similar issue...
  • Thanks 1
