ectonaut Posted November 19, 2002 Share Posted November 19, 2002 Hello: I loaded the iges export plug-in in maya 4 and 4.5 and exported a model. Houdini totally refuses to accept anything. This includes .Iges (for nurbs) and .OBJ (poly). I get that red thingy on the File SOP I'm running maya 4.5 and 4 and houdini 5 and 5.5 Master. I have done this before with maya 3 and houdini 4.1. I tried to bring some rhinoceros 3-D models into houdini that doesn't work either. What's going on? help !!! thanx in advance Quote Link to comment Share on other sites More sharing options...
MG Posted November 19, 2002 Share Posted November 19, 2002 Hmmm, odd. Maybe you should try exporting IGES 5.x (since Houdini might not support higher versions). Quote Link to comment Share on other sites More sharing options...
daland Posted November 20, 2002 Share Posted November 20, 2002 when exporting iges from rhino to houdini...it's very very picky (we have been working with sidefx for about a month on this...) you have to create a new "export type" in rhino with these settings... (General Page) IGES version 5.3 Point Objects: 116(Seperate points) (points and curve page) Mac degree 3 composite curve as single B-spline (checked) Use simple entities when possible (checked) clamp end knots (checked) (surface page) Solids: Seperate solids Polysurfaces: Seperate solids surfaces 144 Max degrees 3 Clamp end knots (only one checked on this page) It's tricky too because you are working with an iges model that someone else built. And it is usually built for another purpose other than visualization. I would also get version 5.5.170 giges has some improvments and nurbs render without artifacts... good luck david Quote Link to comment Share on other sites More sharing options...
ectonaut Posted November 21, 2002 Author Share Posted November 21, 2002 It works !!! Thank you very much. now, If I could only figure out why side fx got rid of the MAT operator in 5.5 sigh. Do I have to learn vex vops now or what ? cheers Luis ps houdini halo is really friggen slow Quote Link to comment Share on other sites More sharing options...
edward Posted November 21, 2002 Share Posted November 21, 2002 ps houdini halo is really friggen slow There have been major improvements if you're using the latest H5.5 build. Have tried it on an Irix box? There has been major headaches with the consumer grade video cards that mainly cater to the games community. Part of it is simply because they don't implement a lot of the OpenGL features in hardware. Quote Link to comment Share on other sites More sharing options...
