xanter Posted April 4, 2019 Share Posted April 4, 2019 Hi ! I have an issue with alembic export from houdini to max , uploaded image. what is wrong with that ? anyone had same issue ? in which format export dop animation from Houdini to max , still all hopes on alembic maybe I'm doing something wrong . Quote Link to comment Share on other sites More sharing options...
kleer001 Posted April 4, 2019 Share Posted April 4, 2019 Are you changing point counts in a single ABC sequence? Are you using individual files for the ABC files? Have you tried to duplicate the bug with a minimal scene setup? Quote Link to comment Share on other sites More sharing options...
Midasssilver Posted April 4, 2019 Share Posted April 4, 2019 Try dropping in a clean sop on your unpacked geo before writing out the alembic. That might fix it. If you are afraid its a Houdini to 3DS max thing, import the alembic back into Houdini and verify if the broken geo is still a thing. Quote Link to comment Share on other sites More sharing options...
xanter Posted April 5, 2019 Author Share Posted April 5, 2019 (edited) Thank you kleer001 and Midasssilver for your responses it was max problem , no such issues in maya Edited April 5, 2019 by xanter 1 Quote Link to comment Share on other sites More sharing options...
