Select one or other in group
Having a brainfart here:
I have a bunch of lines which I'm currently looping over and assigning the end points (ie. has 1 neighbour) into a group. What I now want to do is remove 1 or the other of these two points from the group.
Someone show me what a donut I'm being, please!
I hope that I understood it right. I have attached the file.  You could do "for each primitive" loop and wrangle something like this:
int first = 0;
int last  = -1 + primvertexcount(0, @primnum);
if (@ptnum == first)
   @Cd = {1,0,0};
if (@ptnum == last)
   @Cd = {0,0,1};
Or you could inside one Primitive wrangle:
int first = 0;
int first_pt = primpoint(0, @primnum, first);
int last_pt  = primpoint(0, @primnum, last );
setpointattrib(0,"Cd",first_pt,{1,0,0});
setpointattrib(0,"Cd",last_pt,{0,0,1});
setpointgroup(0, "first", first_pt, 1) ;
setpointgroup(0, "last",  last_pt, 1) ;
first_last.hiplc
I wanted to try a method which works independent of point numbers:
int npoints = npoints(0);
for (int i = 0; i<npoints; i++){
    int group = inpointgroup(0,"end_point",i);
    if (group){
        setpointgroup(0, "end_point",i, 0);
        break;
You would put this in a detail wrangle after you create your end_point group and then replace "end_point" with whatever you named it.
This probably is not the best method for heavy geometry.
just to select random end point per curve without any sop or vex for loops you can do (pointwrangle)
int index = -(rand(@primnum) < 0.5);
int pts[] = primpoints(0, @primnum);
i@group_randomend = pts[index] == @ptnum;
  • Like 2
