CinnamonMetal Posted April 9, 2019 Share Posted April 9, 2019 I want the sphere to be smaller then the bounding box of the line but I'm unable to adjust the size of the sphere in match size ? How do you parent a point to the sphere ? matchSize.hipnc Quote Link to comment Share on other sites More sharing options...
Noobini Posted April 9, 2019 Share Posted April 9, 2019 works fine with a box instead of line. So for a line, you'd have 2 dimensions having scale of 0. How are you going to fit a sphere into a 'box' that has 2 nonexistent axis ? quicker just get line length/2 and set that as sphere radius. Quote Link to comment Share on other sites More sharing options...
CinnamonMetal Posted April 10, 2019 Author Share Posted April 10, 2019 Get the line length by means of an expression and set that value on the sphere radius ? Quote Link to comment Share on other sites More sharing options...
Noobini Posted April 10, 2019 Share Posted April 10, 2019 15 minutes ago, CinnamonMetal said: Get the line length by means of an expression and set that value on the sphere radius ? you could either ref the line length param directly (or relatively I should say) or use measure SOP and sum up perimeter but this is overkill. vu_spheres.hiplc Quote Link to comment Share on other sites More sharing options...
CinnamonMetal Posted April 10, 2019 Author Share Posted April 10, 2019 What I meant was, based on the original scene is; have the sphere to scale based on the length of the line but only, if my measurements are right; a third of the line. Quote Link to comment Share on other sites More sharing options...
Noobini Posted April 10, 2019 Share Posted April 10, 2019 8 hours ago, CinnamonMetal said: What I meant was, based on the original scene is; have the sphere to scale based on the length of the line but only, if my measurements are right; a third of the line. how can it possibly be a third ?...but whatever....it''s your scene, you can do whatever you want, you want a third well simply multiply length by 1/3 you want 2 sevenths ? mult by 2/7....your keyboard....type in whatever you want. Quote Link to comment Share on other sites More sharing options...
