AlexandreTms Posted April 23, 2019 Share Posted April 23, 2019 Hello ! I hope that you all are ok ! I have a problem that I do not understand ! I made a point simulation from a geometry so that it deforms with an elastic effect. I want the final result to keep the uv's basic geometry. I have the VDB, it does not work well. The deform point works almost perfectly, indeed after a certain moment of the simulation, it pushes certain point anyhow and the geometry is badly deformed. I would like to know how to properly adjust the deform point, or another technique to perfectly keep uv if needed ! Thank you ! at_vellum_sticky_uv_OD.hiplc Quote Link to comment Share on other sites More sharing options...
