CinnamonMetal Posted April 28, 2019 Share Posted April 28, 2019 (edited) How to find the tangent direction of a point ? Edited April 30, 2019 by CinnamonMetal Quote Link to comment Share on other sites More sharing options...
CinnamonMetal Posted April 30, 2019 Author Share Posted April 30, 2019 I should have said, how can I rotate a tangent vector ? Quote Link to comment Share on other sites More sharing options...
kiryha Posted April 30, 2019 Share Posted April 30, 2019 To rotate vector (N) with matrix (you can also rotate vector with quaternions or euler): // Set orientation vector: normal @N = {1,0,0}; // create matrix matrix3 matrx = ident(); float angle = -radians(chf('Rotation_Y')); // rotate matrix rotate(matrx, angle, {0,1,0}); // Apply rotation @N *= matrx; To create a vector from 2 points you just need to subtract their positions. If you have only one point you can use origin as a second position. 1 Quote Link to comment Share on other sites More sharing options...
CinnamonMetal Posted April 30, 2019 Author Share Posted April 30, 2019 (edited) Ok, how do you get two vectors to point at each other, or that ties in with vector subtraction. Edited April 30, 2019 by CinnamonMetal Quote Link to comment Share on other sites More sharing options...
kiryha Posted April 30, 2019 Share Posted April 30, 2019 I did not understand your question, Christopher... But the position of a vector does not matter (if we are not speaking about the spetial type of vectors - positional vectors), you can move a vector anywhere in 3D space and it would be the same vector. Quote Link to comment Share on other sites More sharing options...
CinnamonMetal Posted May 2, 2019 Author Share Posted May 2, 2019 Thanks it helped Quote Link to comment Share on other sites More sharing options...
