Intro level hardware for Houdini
Garry
Hi all,
I'm new to VFX, in search of a computer to get started with Houdini.  My best guess at this point is a mid- to high-range gaming PC.  Specs I'm considering: (below)  Would this machine work at the intro level?  Thanks.
Intel® Core™ i9 9900K (8 Core/16 Threads, up to 4.7GHz on all cores, 16MB Cache)
NVIDIA® GeForce® RTX 2080 OC with 8GB GDDR6
16 GB Dual-Channel-DDR4 at 2.666 MHz
256 GB M.2-PCIe-NVMe-SSD + 2 TB SATA
Windows 10
Looks ok but definitely like CinamonMetal says, you should get more RAM... 32GB will be much better for the start and the second think in my opinion would be better to start with CPU like threadripper 1920X.
this is perfectly good for running Houdini, but I wouldnt call it entry level hardware for sure. it's better than what i have at home and that was some pretty dear high end stuff just a year ago :) if you want entry i'd opt for something much more humble if budget is of any importance to you. just saying :) consider 16gb ram a bare minimum thou.
Thanks.  You're right: I'm what's entry level, not the computer.  The nice thing is that everything is easily upgraded nowadays, RAM, video card, etc.  My main concern was being able to run Houdini in some reasonable fashion to get started.  The kind folks at SideFX gave me input too after I posted here.  17/17.5 seems to be a big step up from previous versions, so I may have gotten lucky as far as that goes too.
