nicoladanese Posted May 6, 2019 Share Posted May 6, 2019 Hey! I'm looking into a way of keeping my volume inside the vortex boundaries, at the moment when it spins it goes out, any idea? I was thinking about a torus shape volume around it with custom velocities to push it inside when it goes out, but maybe there are better solutions! cheers! Quote Link to comment Share on other sites More sharing options...
Midasssilver Posted May 6, 2019 Share Posted May 6, 2019 Yeah, you need some velocity pushing the smoke inwards. If you don't angle the velocity inwards, it's just going to shoot outwards from the spin. If I were you, I'd set up another velocity field that just sucks the smoke inwards and get that looking good, then add an additional velocity force that adds the radial velocity, and add just enough that the smoke doesn't shoot out too far. Quote Link to comment Share on other sites More sharing options...
rayman Posted May 8, 2019 Share Posted May 8, 2019 (edited) You can add single Gas Field Wrangle into the velocity update plug and try something like this: float minrad = 1; float maxrad = 1.5; float velmult = 1.0; vector center = set(0,0,0); vector dir = center-v@P; float dist = length(dir); float mult = fit(dist,minrad,maxrad,0,1)*velmult; v@vel += normalize(dir)*mult; Edited May 8, 2019 by rayman Quote Link to comment Share on other sites More sharing options...
nicoladanese Posted May 8, 2019 Author Share Posted May 8, 2019 hey! thanks for your reply Joseph, I wonder if I can manipulate the existing velocity adding a bit of inward velocity rather than adding a custom field, I need to dig a bit more in how to customize data inside the pyro solver! anyway I think this is the easy way, although requires a lot of try and fail to get the right amount Pavel, thanks for the vex code, will definitely try this as well since I'm using that volume to move points, what I'm doing at the moment is doing the tornado at point level rather than volume, definitely easier to setup Quote Link to comment Share on other sites More sharing options...
