lim_flamingo Posted May 8, 2019 Share Posted May 8, 2019 (edited) Just like in the picture, the particles in the tail will be missing a part of the ship's movement. Who can tell if there is any problem? Thank you. Edited May 9, 2019 by lim_flamingo Quote Link to comment Share on other sites More sharing options...
lyansart Posted May 9, 2019 Share Posted May 9, 2019 hello, you probably need way more particle separation, and as well a little bit of depth. is this right scale? Quote Link to comment Share on other sites More sharing options...
lim_flamingo Posted May 9, 2019 Author Share Posted May 9, 2019 53 minutes ago, lyansart said: 你好,你可能需要更多的粒子分离,以及一点点深度。这是正确的规模吗? I have tried to improve the particle precision, but I still have the following picture, and the whole scene is probably half-scaled, In depth, because the current version uses the Narrow band Flip, so I have to reach the bottom of the hull in depth? The size of the hull, I have shrunk by half, the actual scene is too big, 250 meters, the computer can not stand, Thank you! Quote Link to comment Share on other sites More sharing options...
tamagochy Posted May 9, 2019 Share Posted May 9, 2019 yes you should increase depth of narrow band layer Quote Link to comment Share on other sites More sharing options...
lyansart Posted May 10, 2019 Share Posted May 10, 2019 Fluid are heavy in houdini, and they will need a strong computer for simulating + meshing + whitewater + rendering! You are harly gonna get a fine mesh if your particle separation isn't hight enough. But if that's just a test for fun, then at least I would suggest to scale it by 0.1, and work on a small scale, in order to have more resolution. Quote Link to comment Share on other sites More sharing options...
lim_flamingo Posted May 14, 2019 Author Share Posted May 14, 2019 On 2019/5/10 at AM8点58分, lyansart said: houdini中的流体很重,他们需要一台强大的计算机来模拟+网格+白水+渲染! 如果你的粒子分离不够高,你很难得到一个精细的网格。但是,如果这只是一个有趣的测试,那么至少我建议将其缩放0.1,并在小规模上工作,以便获得更高的分辨率。 thank you , I will try again Quote Link to comment Share on other sites More sharing options...
lim_flamingo Posted May 14, 2019 Author Share Posted May 14, 2019 On 2019/5/10 at AM12点25分, tamagochy said: 是的,你应该增加窄带层的深度 all right,thanks~ Quote Link to comment Share on other sites More sharing options...
