Execute Expression
Rafal123
hi,
Can anybody help to solve this type of problem?
How to execute expression in string data type?
I wanna H execute first expr in "somethin here" and then to execute the rest
Example:
ch("../sss1/f1") --> instead sss1 I wanna have --> sss`opdigits(".")
ch("../sss" + opdigits(".") + "/f1")
28748[/snapback]
hey edward thanks for answer it works but I have one more question,
why in --> "" we don't use --> ' ? and when we write in standard way there is --> '
in example:
in node file --> cop
I put there: $HIP/frame`opdigits(".")`.tga
but when I wanna execute --> opdigits in --> "" there is no need for--> '
:ph34r:
Can You explain that?
in example:
:ph34r:
28753[/snapback]
If you do something inside of a text field you're in the text world. Therefore if you need to calculate expression inside of a text field, you use backticks. They specify that a part of the text it not a plain text but an expression which is necessary for calculating. In other cases you're in the expressions world and backticks isn't necessary.
Exception is a global variables which can be used both with backticks and without them.
28763[/snapback]
hey hoknamahn, many thanks for an explanation now it's more clear
