Expressions in file names. Mantra output file
Hey guys,
How can I change the path in mantra Output file
to: V:/projectname/shotname/fx/geo
can`t figure out how to run strreplace twice.
this doesn`t work: `strreplace($HIP, P:, V:)` `strreplace($HIP, work/houdini/hip, geo)`
$HIP is P:/projectname/shotname/fx/work/houdini/hip
also + is to add to the path, how can i subtract from the path?
Cheers
Janis
Got it.
`strreplace(strreplace($HIP, work/houdini/hip, geo), P:, V:)`
 no backticks if you put expression function in to an expression function.
Still don`t get it properly. When to use any of those 3: `' "
ch('whatever') ch("whatever") works both in vex.
Where could I find proper info about those guys (`' ")?
Cheers
