RBD pre-solve intersection?
zjie
Hi guys, I am doing a simulation where the rbd objects will fill up a box partition, however, they were already intersecting before the simulation. When they were sim-ed, some were still intersecting and sticking on each other, hence is there a way to pre solve the intersection before the simulation?
rbd_test_v001.hip
Edited by zjie
12 hours ago, vicvvsh said:
Hi, set point attribute i@found_overlap to 1 on your packed primitives in SOP. Then in DOP Network into the rbdpackedobject1 turn on parameter Solve on Creation Frame.
Thanks, this helps!
