Errors while rendering
I use houdini 17
and while I'm rendering with mantra with default render settings
Error occurs
Houdini console shows
OpenCL Exception: clFinish (-36)
OpenCL Context error: CL_OUT_OF_RESOURCES error executing CL_COMMAND_READ_BUFFER on GeForce GTX 1060 3GB (Device 0).
OpenCL Exception: clEnqueueReadBuffer (-5)
OpenCL Context error: CL_MEM_OBJECT_ALLOCATION_FAILURE error executing CL_COMMAND_WRITE_BUFFER on GeForce GTX 1060 3GB (Device 0).
OpenCL Exception: clEnqueueWriteBuffer (-4)
Any suggestion,  please?
Hi!
What are you rendering? It's a sim? Is it cached on disk or is simulating and rendering?
From those messages is seems like the video card is running out of memory, but if it's just a render and not a sim running on OpenCL ... that's strange.
Can you share the hip?
1 hour ago, merlino said:
Hi!
It could be easy for you to analyze, what the problem is, so, I'd like to share
but
I'm afraid that I can not share the hip file because the file is made when I was following a paid online tutorial. I don't want any trouble with the instructor.
Anyway, I was rendering cached moving geometry, foam, white water, and fluid simulation.
As soon as I read your post I checked that I cached simulation.
And I found that I made cache files of "compressed_cache" of the fluid simulation, but I did not make a cache of "surface_cache".
Then, I started making a cache file of the "surface_cache", Houdini shows the same error message afterward.
So I checked the points number, it was 3.6mil.
Is this a High setting for my hardware?
My cpu is AMD Ryzen 7 2700, ddr4 ram 64gb, Geforce GTX 1060 3gb, and my hdd is 4TB.
I attached a screen shot of "particlefluidsurface".
Edited by crow9350
