Scene viewport : Set path from node button press
LaidlawFX
Hello,
I am trying to set the path of the current scene viewport via a button press from a hda.
I know these python docs below are the key, but I can't seem to tie the relevant python functions together.
https://www.sidefx.com/docs/houdini/hom/hou/PaneTab.html
https://www.sidefx.com/docs/houdini/hom/hou/PathBasedPaneTab.html
https://www.sidefx.com/docs/houdini/hom/hou/SceneViewer.html
https://www.sidefx.com/docs/houdini/hom/hou/GeometryViewport.html
Any help would be great.
Thanks,
-Ben
Ok I figured it out a bit based on this chat.
This code was put into the Python Source Editor. If you have a geometry object /obj/geo1 in your scene, it will change the path of the SceneViewer to node. It will do a simple check if it is pinned and pin it. Probably could use a bunch of exceptions...
import hou
node = hou.node('/obj/geo1')
scene_pane = hou.ui.curDesktop().paneTabOfType(hou.paneTabType.SceneViewer)
if scene_pane.isPin() :
    scene_pane.setPin(False)
scene_pane.setPwd(node)
scene_pane.setPin(True)
https://www.sidefx.com/docs/houdini/hom/hou/ui.html
to
https://www.sidefx.com/docs/houdini/hom/hou/Desktop.html
which needs one of these
https://www.sidefx.com/docs/houdini/hom/hou/paneTabType.html
Then you can use these.
Hope that helps future me, and other fine folks.
