Can't get density from houdini to maya redshift
JackAry
Hey, total noon here :)
Just started learning houdini recently. Made a candle flame and adjusted it like I wanted it. When I am converting it to VDBs I can't get the density right and thus it looks wrong or is invisible in maya.
The file is attached, any help is appreciated :D
CandleJet.hip
In pyro import :
Connect the import_pyrofield to a convertvdb node. In the group field enter @name = density @name = temperature etc...
Put a file node behind it in write mode. Once you Activate the display or template flag, vdb files are writting.
This is what I do to go to Cd4. Working fine.
