Mozzarino Posted July 2, 2019 Share Posted July 2, 2019 Hello everyone, I have a setup where I need to cache different bgeos along the way. For this I set up various file cache nodes (collider volume -> flip sim -> flip vdbs -> whitewatersource -> whitewatersim). I'm wondering if there is any way to run this multiple file cache nodes in an orderly fashion? Cheers, Diogo Quote Link to comment Share on other sites More sharing options...
celd Posted July 2, 2019 Share Posted July 2, 2019 This is exactly what you can use the new TOPs for - They give you the option to run these water simulations essentially at the same time, with caches further down the stream beginning to run as soon as their dependencies are available. Quote Link to comment Share on other sites More sharing options...
3dome Posted July 2, 2019 Share Posted July 2, 2019 (edited) apart from TOPs you can always use Fetch ROPs and wire them together in the desired fashion edit: also have a look at this Edited July 2, 2019 by 3dome Quote Link to comment Share on other sites More sharing options...
Mozzarino Posted July 2, 2019 Author Share Posted July 2, 2019 thanks for the tips! Will have a closer look at both options. Cheers, Diogo Quote Link to comment Share on other sites More sharing options...
CorvaenOboros Posted September 21, 2019 Share Posted September 21, 2019 A quick way to update all the filecaches can be using a PythonScript node as well , using it in TOPS is a good way ive found to trigger it in sequence . and unlike ROPFetchs in TOPs you dont need to create a explicit node for each filecache . import hou from nodesearch import parser # Create a matcher that finds nodes whose name contains filecache matcher = parser.parse_query("*filecache*") network = hou.node("/obj/") for node in matcher.nodes(network, recursive=True): node.parm('execute').pressButton() This looks for all nodes with "filecache" in their name and triggers their Save to Disk button ( execute ) . the nodesearch function can also do "match only on multiple" queries ( more details in the help https://www.sidefx.com/docs/houdini/hom/nodesearch.html ) as long as named your filecache nodes something like "flip_sim_filecache_01" and "whitewater_filecache_07" then you could have a string of Python nodes in TOPS searching for and caching all nodes of that type in order ( the first nodesearch looking for *flip* and *filecache* , then the next python node looking for the *whitewater* + *filecache* nodes ) . this was ideal for a project that has potentially lots of different filecaches that you dont want to explicitly path to . Quote Link to comment Share on other sites More sharing options...
