hampuseh Posted July 3, 2019 Share Posted July 3, 2019 I get this warning when I render with redshift in Houdini. The instance object "/obj/REDSHIFT_TEMP_PACKED_GEO/_obj_bla_blabla_blablabla_blabla_blabla_blabla_blabla_blabla_bla_tree156683" is not available as a RSMeshBase or RSProxy object, perhaps it is hidden in the scene" So I have a couple of hundred trees that I have packed and instances with a copy to points, I have ticked on "instance SOP level packed primitives" on the Redshift obj section of the geometry sop. It seems that a specific instance of the tree is not working properly, and I do not know what Temp Packed Geo means. It doesn't stop the rendering but I am assuming that it adds some extra time on the actual render time. Quote Link to comment Share on other sites More sharing options...
blanquitto Posted November 24, 2019 Share Posted November 24, 2019 Iget the same problem with the same message now Do you find a solution for this? I have make a trees instances and redshift works well but i make the same process with rocks instances and it doesnt work.... i dont understand Quote Link to comment Share on other sites More sharing options...
AustinW Posted December 28, 2021 Share Posted December 28, 2021 Just chiming in to say I'm having the same problem... Did you two ever figure it out? Quote Link to comment Share on other sites More sharing options...
Sepu Posted December 29, 2021 Share Posted December 29, 2021 can you share the .hip or repro scene where this is happening? Quote Link to comment Share on other sites More sharing options...
AustinW Posted December 29, 2021 Share Posted December 29, 2021 41 minutes ago, Sepu said: can you share the .hip or repro scene where this is happening? I found the problem (and it's obvious in hindsight) but one of my 28 instances had no geometry, I removed it and error gone. Quote Link to comment Share on other sites More sharing options...
