In "Principled Shader/ Bump & Normals", what is "Image Plane"?
Hi;
In "Principled Shader/ Bump & Normals", there is an option called "Image Plane". I can't find any useful document about it. So, what is this tab for and how could I create an Image Plane?
Is this for using COMPs as a texture input?
Thanks.
Edited by Masoud
On 7/16/2019 at 8:01 PM, LaidlawFX said:
Not sure why it is called image plane at that level.
https://www.sidefx.com/docs/houdini/nodes/vop/texture.html
Texture Channel
This specifies which color channel for multi-plane textures should be evaluated.
Thank you "LaidlawFX", so is there any example or tutorial about how to use it?
If you have a multi plane texture like a .exr, or a rendered image from mantra extra image planes you just type in the name of the channel.
In the attached scene it loads up temp.exr which is a combo of the butterfly and mandril. They are on channels Cr and C respectively. With Cr typed into the respective parameter it renders that image instead. You can use mplay, to view the different channels in the .exr.
temp.exr
MultiChannelTexture.hip
Edited by LaidlawFX
Re-uploaded files
