bentraje Posted July 23, 2019 Share Posted July 23, 2019 (edited) Hi, I'm trying to follow an old tutorial but I am having a problem where the author used the old VOPSOP and I'm using the attribute VOP. The main problem is in the display of colors. You can see an illustration of the problem here: https://www.dropbox.com/s/0u9irdhbbodxm3b/hou004_vopsop_attribvop_color.jpg?dl=0 You can also check the illustration file here: https://www.dropbox.com/s/hsiyitkn4kn2vvi/hou004_vopsop_attribvop_color.hipnc?dl=0 Is there a way around this? Thank you for looking at my problem. Edited July 23, 2019 by bentraje Quote Link to comment Share on other sites More sharing options...
cudarsjanis Posted July 23, 2019 Share Posted July 23, 2019 Hard to tell without the .hip But could be something to do with Search radius in pcopen maybe? 1 Quote Link to comment Share on other sites More sharing options...
Gorrod Posted July 23, 2019 Share Posted July 23, 2019 You have not plugged in your @P attribute into the pcopen. Fix that and you're good to go. The VOPSOP might bind the position automatically if not done manually. 1 Quote Link to comment Share on other sites More sharing options...
bentraje Posted July 23, 2019 Author Share Posted July 23, 2019 @cudarsjanis @Gorrod Thanks for the response! Plugging the @P attribute into pcopen did the trick. Have a great day ahead! Quote Link to comment Share on other sites More sharing options...
cudarsjanis Posted July 23, 2019 Share Posted July 23, 2019 2 hours ago, Gorrod said: You have not plugged in your @P attribute into the pcopen. Fix that and you're good to go. The VOPSOP might bind the position automatically if not done manually. ahh yes. That`s what I thought. looks weird not plugged in but maybe that works as well Quote Link to comment Share on other sites More sharing options...
