Saya Posted July 26, 2019 Share Posted July 26, 2019 Hi Odforce, Im trying to find a way to extrude a square along a curve. the start of the square should fit the shape, orientation and such from its orgin. The idea is that the curve is adjustable and replaceable with other (open) curves going in other directions. I've thrown polyframe, and polyextrude with a curve from second input and more but I seem to miss something. Some help is really appreciated. Thanks in advance Sphere square extrution.hipnc Quote Link to comment Share on other sites More sharing options...
Saya Posted July 29, 2019 Author Share Posted July 29, 2019 Perhaps I was unclear. The start of the curve works if i turn off "Transform Using Point Orrientation" but then the end gets weird. Hope this clarifies the problem. Thanks in advance again! Quote Link to comment Share on other sites More sharing options...
Jesper Rahlff Posted July 29, 2019 Share Posted July 29, 2019 You can try to use the polyextrude node and then input your curve to the second input and extrude along that curve. Quote Link to comment Share on other sites More sharing options...
Saya Posted July 29, 2019 Author Share Posted July 29, 2019 (edited) Thanks jesper! I've done this but then it doesn't extrude along the actual shape of the curve. It cramps part of the curve from the start to end position as if end extrusion did not transform along the curve. Hope this is a clear explanation. You may view the issue in the Houdini file. resulting in this. the extrusion does not actually follows the line Edited July 30, 2019 by Marcomeeuwse adding screenshot Quote Link to comment Share on other sites More sharing options...
Saya Posted July 30, 2019 Author Share Posted July 30, 2019 I approached it in another way. I used polyextrude. Gave it some divions and applied an bend on it! Thanks for the help though Jesper Quote Link to comment Share on other sites More sharing options...
Werner Posted July 30, 2019 Share Posted July 30, 2019 (edited) Too late, but you could also just use a polywire on the curve. Then use Polybridge between the sphere and the polywire. That way you can edit the curve at hearts content. Pbridge.mp4Fetching info... PBridge.hipnc Edited July 30, 2019 by Werner Quote Link to comment Share on other sites More sharing options...
Saya Posted July 31, 2019 Author Share Posted July 31, 2019 Ah nice! even with video! I think I will adapt to this method Quote Link to comment Share on other sites More sharing options...
