iter each copy transform
Sounds like your for-each is running over each prim rather than each level. You can add an "assemble" sop before the for-each and try selecting "for-each named primitive" from the tab menu. Or just check the "Piece attribute" parameter and set the appropriate attribute name.
7 minutes ago, Aizatulin said:
Another option can be randomizing the scale of each level and adding it on top of the current stack. The current height of the stack can be measured to calculate the right offset.
jl_iterLevel_01_X.hipnc
This is exactly what I was thinking! Thanks for taking a look I really appreciate it!
