philpappas Posted August 13, 2019 Share Posted August 13, 2019 (edited) i'm trying to connect each point with the next one and then the centroid what am i doing wrong? seems simple enough (maybe there is a node for that) ideally i want to make also edge loops after like concetric circles connect_to_center.hip Edited August 13, 2019 by philpappas Quote Link to comment Share on other sites More sharing options...
ikoon Posted August 13, 2019 Share Posted August 13, 2019 Hi philpappas. In your vex, you use i to iterate over the points. At the same time, you use i as an prim_num argument in addvertex here. int addvertex(int geohandle, int prim_num, int point_num) So this might be a problem. Also it seems, that you may want the polyline, instead of the poly? I am not exactly sure, how the result should look like, but I attach a node solution for inspiration. I might help you with the vex too, but please clarify your intention. connect_to_center - v1.hiplc 1 Quote Link to comment Share on other sites More sharing options...
Aizatulin Posted August 13, 2019 Share Posted August 13, 2019 Hi, it works for me if you replace "i" in addvertex by "prim0" (even if type is "poly"). 1 Quote Link to comment Share on other sites More sharing options...
philpappas Posted August 13, 2019 Author Share Posted August 13, 2019 6 hours ago, ikoon said: Also it seems, that you may want the polyline, instead of the poly no i wanted "poly" and it worked great when i swapped i for prim0 in each addvertex function! thanks!! your method is interesting no vex, i'll have a look Quote Link to comment Share on other sites More sharing options...
ikoon Posted August 13, 2019 Share Posted August 13, 2019 Here is that "node" method, with poly output. Hiplc is attached too. connect_to_center - v2.hiplc Quote Link to comment Share on other sites More sharing options...
philpappas Posted August 13, 2019 Author Share Posted August 13, 2019 23 minutes ago, ikoon said: "node" method great, now i'm not so sure this was the right method all along because i wanted to enumerate the prims as you see in the attached image. kind of a reversed matrix (thats how i'd do it in grasshopper) i should probably construct the prims using the radial lines one by one and attach an attribute for each layer(?) ...i can think of ways but maybe i am over complicating it Quote Link to comment Share on other sites More sharing options...
ikoon Posted August 13, 2019 Share Posted August 13, 2019 I am really not sure, if this is the best solution. I also feel like overcomplicating it BTW I have hardcoded 10 iterations. You can change that. connect_to_center - v2.hiplc Quote Link to comment Share on other sites More sharing options...
ikoon Posted August 13, 2019 Share Posted August 13, 2019 As Mark Twain said: “I didn’t have time to write a short letter, so I wrote a long one instead.” Quote Link to comment Share on other sites More sharing options...
philpappas Posted August 13, 2019 Author Share Posted August 13, 2019 (edited) 38 minutes ago, ikoon said: As Mark Twain said: “I didn’t have time to write a short letter, so I wrote a long one instead.” hahah nice! i'll take a sip of coffee and read this one Edited August 13, 2019 by philpappas Quote Link to comment Share on other sites More sharing options...
anim Posted August 13, 2019 Share Posted August 13, 2019 or something along these lines (contains layer and wedge attribs) connect_to_center_3.hiplc 1 Quote Link to comment Share on other sites More sharing options...
