Black in glass
blob.png.4a7c03a2b0d3361f9b6b41152f785600.pngblob.png.393d1a09b94e9bf88abdad743203ef84.png
We're looking down on a wineglass with liquid in it.
Anyone know why I'm getting this thick black edge along the top edge of the wine glass? (Left image is refraction pass, right image is beauty pass)
It occurs when I drop raytracing bias down to a small value - say 0.0001 - I need this to be this small in order for my bubbles to render correctly.
The glass shader is a principled shader, ior 1.5, transparency 1, fake caustics on, PBR.
There are a few things that could be causing the issue. If you don't have enough things to reflect, like a sky or HDR, that can cause it. Black in your refractions can also come from not having a high enough trace depth.  Changing the bias changes the way refractions are computed, but it wouldn't remove or the black or fix the problem, it is probably just distorting it to angle small enough where you can't see it.
