Importing AutoCAD file into Houdini, issue ...
Masoud
Hello;
I tried to import an AutoCAD drawings file into Houdini, but here are some problems: I saved my CAD file as "DXF", but only DFX files saved in "AutoCAD R12" can be imported (other versions doesn't works !), and this imported file is somehow corrupted ! (look at image bellow).
Any idea?
(My DXF and AutoCAD file is attached here).
Thanks.
MSD_CentralCore_01.dxf
MSD_CentralCore_01.dwg
Edited by Masoud
I realized if I turn OFF the " Linetype Generation" option in AutoCAD, the problem will be solved. So in AutoCAD:
1) type "PEDIT"
2) Press "M" for multiple selection
3) Select all lines
4) Select "Ltype gen"
5) type "OFF"
6) Press " Enter " twice.
7) Save your file
8) Enjoy.
:D
Edited by Masoud
