Redshift instancing, what am I doing wrong?
I'm trying to instance simple sharp rectangular geo onto scattered points to create a frost effect.
I've tried 3 methods:
- The copy to points sop (w/ pack and instance)
- Adding the s@instance attrib with a path to the geo
- Using the instance node at obj level
When rendering with around 1000 points I get a decent preview quickly in the IPR but a full render at 256 samples still takes far too long.
If I try to up the point count to something like 50k, I struggle to get any feedback from the IPR. If I go to 100k I get no feedback in the IPR, it just freezes. When I try to render to disk, the render doesn't even begin.
What am I doing wrong? From what I've seen I should be able to achieve 100k instances fairly easily if I'm not mistaken.
I appreciate any help!
Specs: i7-6700k, GTX 1080, 16GB RAM
Edited by justAero
Cat stepped on keyboard and posted this incomplete
