How to have 2 objects stay together when deforming?
Krion
Thanks for your reply.
The subdivide didn't work but through a discord channel @mestela made me discover the Point Deform tool and that works properly. :)
Quote
creep sop I think is the usual way
But these days I'm super lazy and just point deform everything
Have your text flat at origin, lying on a flat version of your ribbon
Point deform the text, give it the flat ribbon as rest geo, bendy ribbon as target
Then you can use a transform sop on the text before the point deform to slide it up and down, the should move the deformed text along the ribbon
