kubabuk Posted July 20, 2006 Share Posted July 20, 2006 Hi guys, very simple question. How can I connect two nurbs curves that one inherits direcion of the other, I tried to fuse vertices but still have two separeted objects...?!? Have I missed some very straightforward SOP? stitch, join, fillet don't work for me Probably I am stupid... (it's so hot here) Thanks kuba Quote Link to comment Share on other sites More sharing options...
sanostol Posted July 20, 2006 Share Posted July 20, 2006 try this: wire the 2 curves into a mergesop and to this append a joinsop martin Hi guys, very simple question. How can I connect two nurbs curves that one inherits direcion of the other, I tried to fuse vertices but still have two separeted objects...?!? Have I missed some very straightforward SOP? stitch, join, fillet don't work for me Probably I am stupid... (it's so hot here) Thanks kuba 1 Quote Link to comment Share on other sites More sharing options...
kubabuk Posted July 20, 2006 Author Share Posted July 20, 2006 Thank you so much!!!! such a straightforward solution. Cheers Kuba Quote Link to comment Share on other sites More sharing options...
Marc Posted July 25, 2006 Share Posted July 25, 2006 If you work in the viewport, then you can merely plonk downa join SOP and it will automagically merge the two together for you. It will also put a reverse SOP down if it's needed on one of the curves. Ciao M Quote Link to comment Share on other sites More sharing options...
